No sound driver.....
  • Please log in to reply
36 replies to this topic
#21 guestolo
guestolo
    Site Donator
  • Admin
  • PipPipPipPipPipPipPip
  • 16,247 posts
Posted 19 September 2006 - 12:14 PM
Go back to Device Manager
Right click on microsoft WINMM WDM Audio compatible
and click Uninstall
Afterwards reboot the computer
Do you get sound?
What other entries do you have under Sound,Video and Game controllers in device manager
Follow the instructions posted Click Here
#22 FIxeL
FIxeL
    Enthusiast
  • Members
  • PipPipPipPip
  • 145 posts
Posted 19 September 2006 - 01:46 PM
Ok, i uninstaled the that microsoft WINMM WDM Audio didnt got any sound, but now in is place shows ,,unknown device" when i try to update it , it shows an error ,,driver is not intended for this platform"
and these are other devices: Audrio Codecs,Legacy audio driver,legacy video capture devices,media control devices,soundMax intergrated digital audio,standart game port,unknown device,video codecs,winfasttv2000 XP Expert WDM Crossbar,winfasttv2000 XP Expert WDM TVTuner,winfasttv2000 XP Expert WDMvideo capture
Posted Image
#23 guestolo
guestolo
    Site Donator
  • Admin
  • 16,247 posts
Posted 19 September 2006 - 01:53 PM
Is this a legal version of XP?
I was now going to suggest visiting Windows updates
selecting the 'Custom' button to check for updates. Once finished checking, on the left-hand menu there is a 'Hardware, Optional' type link.
See if there is a driver update for the 'Microsoft WINMM WDM Audio Compatibility Driver'. If there is, mark the check box next to it for download, and then 'Review and install updates'.
If this isn't a legal version of XP
You probably won't be able to access Windows updates
What happens when you go and run New Hardware in Control panel
Anything found?
#24 FIxeL
FIxeL
    Enthusiast
  • Members
  • PipPipPipPip
  • 145 posts
Posted 19 September 2006 - 02:05 PM
well its a legal version (kinda) check PM but there isnt in hardware update any sound driver update only lg monitor...
Posted Image
#25 FIxeL
FIxeL
    Enthusiast
  • Members
  • PipPipPipPip
  • 145 posts
Posted 19 September 2006 - 02:17 PM
oh and when i see in the control panel add hardware it shows the sound driver ,,MEDIA" with yelow mark and says ,, driver not instaled"
Posted Image
#26 guestolo
guestolo
    Site Donator
  • Admin
  • 16,247 posts
Posted 19 September 2006 - 05:14 PM
Try reinstalling your sound driver
You can download it from this direct link, the website is slow
Click Here
Save the zip file to your desktop
Then ensure that you UNZIP the contents to a folder of it's own on your desktop
Don't try and run it from within the zip file
Open the folder and run setup.exe
Follow the prompts
Reboot when prompted
Does that help you out
Any problems in device manager?
#27 FIxeL
FIxeL
    Enthusiast
  • Members
  • PipPipPipPip
  • 145 posts
Posted 20 September 2006 - 09:54 AM
i didnt everything that u said. But there still isnt any sound and theres still in device manager yellow mark on ,,unknown device" (Microsoft WINMM WDM Audio Compatibility Driver)
Posted Image
#28 Loveme
Loveme
    Enthusiast
  • Members
  • PipPipPipPip
  • 126 posts
Posted 20 September 2006 - 10:10 AM
buy one.
My msn = [email protected] Removed.co.uk
Swapping a lvl 122 for a good pure
#29 guestolo
guestolo
    Site Donator
  • Admin
  • 16,247 posts
Posted 20 September 2006 - 10:12 AM
Go back into Device manager
Double click on Microsoft WINMM WDM Audio Compatibility Driver click on troubleshoot
If that can't resolve it
Delete Microsoft WINMM WDM Audio Compatibility Driver
REBOOT the computer
Any luck?
#30 FIxeL
FIxeL
    Enthusiast
  • Members
  • PipPipPipPip
  • 145 posts
Posted 20 September 2006 - 10:51 AM
now its called unknown only in troubleshoting or update drriver shows its full name
othervize it shows unknown driver
Posted Image
#31 guestolo
guestolo
    Site Donator
  • Admin
  • 16,247 posts
Posted 20 September 2006 - 11:24 AM
Did you delete(Uninstall) it and reboot the computer?
I'm not sure what's happening on your end
Where did you buy this computer from?
Can you run Belarc advisor again
What info is supplied under System model in the top right?
Right click MyComputer>>Select Properties
What is the manufacturer and model
I just want to make sure you posted back what I need
#32 FIxeL
FIxeL
    Enthusiast
  • Members
  • PipPipPipPip
  • 145 posts
Posted 20 September 2006 - 12:25 PM
i buyed like 4 years ago from a shop (dont remember the name )
i can delete that file ,,unkown driver '' like 100's of times but it reapears after reboot
System Model: No details available
My Cpmuter- System : Microsoft Windows XP
Professional
Version 2002
Service Pack 2
Computer: Intel®
Pentium ® 4 CPU 2.60GHz
256MB of RAM
Posted Image
#33 guestolo
guestolo
    Site Donator
  • Admin
  • 16,247 posts
Posted 20 September 2006 - 12:40 PM
I'm not sure what your problem is
What hardware have you added to this computer since you owned it?
Did you reopen the back of your computer and ensure that everything was hooked up properly>
Last attempt then you will have to troubleshoot on your side unless I can find the problem on google or elsewhere
Remove any external periphials hooked to the computer
ONLY leave your mouse and keyboard hooked up
Reinstall sound drivers from the download
earlier found in the Soundmax folder you unzipped
Reboot ONLY if prompted
afterwards, go back to Device manager and remove
Microsoft WINMM WDM Audio Compatibility Driver if it has yellow exclamation
Reboot one more time
any luck
Give back as much info as you can
Did you install anything else besides your CDrom before you lost sound
When did you install Winfast
#34 FIxeL
FIxeL
    Enthusiast
  • Members
  • PipPipPipPip
  • 145 posts
Posted 26 September 2006 - 09:23 AM
Srythat i didnt replay for so long was out of town :(
1. No i didnt add anything after i owned this computer just changed flopy drivrer... :)
2.Yes i checked 3 times the back of computer and everything is ok
3.Nop, nothin... the Microsoft WINMM WDM Audio Compatibility Driver reapears after reboot...
4.Well not completly shure but i think i instaled the stardock dektop custemizer. Dont remeber for sure but i think my computer crashed and then i lost my sound...
5. WinFast i have for 3 years :) thats it...
Posted Image
#35 FIxeL
FIxeL
    Enthusiast
  • Members
  • PipPipPipPip
  • 145 posts
Posted 03 October 2006 - 08:27 AM
so wat should i do? or just call the specialists?
Posted Image
#36 guestolo
guestolo
    Site Donator
  • Admin
  • 16,247 posts
Posted 03 October 2006 - 09:52 PM
I have no idea what's going on at your end
Wish I was there to help you out, but sometimes, on hands help may help
Have you thought about clean installing or repair your Operating system?
#37 FIxeL
FIxeL
    Enthusiast
  • Members
  • PipPipPipPip
  • 145 posts
Posted 04 October 2006 - 09:29 AM
you taling about formating?
Posted Image
