problems with real player and media player
  • This topic is locked This topic is locked
66 replies to this topic
#61 big frank
big frank
    Member
  • Members
  • PipPipPip
  • 52 posts
Posted 13 December 2008 - 06:09 PM
Just on our way out to get an Xmas tree, I'll be back in less than a couple hours
Check back then please
If it's only that one small video, it's very short
Maybe your starting it and it ends right away
As said, check your other video files, see if you can get them to lock up, if not, you could be good
I tried a couple other videos and sure enough they froze. I hoping if I try another player, maybe just maybe. While your getting your tree, I'll be putting ours up.
#62 guestolo
guestolo
    Site Donator
  • Admin
  • PipPipPipPipPipPipPip
  • 16,247 posts
Posted 14 December 2008 - 02:13 AM
Well, we got our tree, dogs had a great run too :)
Sure, why don't we try another media player
Can you do the following please
Download and save to desktop the installer for Gom Player from the following link
http://www.gomlab.co...P_download.html
Double click on it to install
Leave all defaults selected
ONLY untick "Google toolbar" selection when installation
After installing, try running some of your video files
Don't be concerned if most/all icons have changed to Gom icons for Video, etc...
We can change that easily
But at least we can see if you can run all your files
Follow the instructions posted Click Here
#63 big frank
big frank
    Member
  • Members
  • PipPipPip
  • 52 posts
Posted 14 December 2008 - 06:17 AM
Ok that seemed to do the trick. I even played the first video on the video test page. I hadn't been able to play that one.
#64 guestolo
guestolo
    Site Donator
  • Admin
  • 16,247 posts
Posted 14 December 2008 - 10:41 AM
Well, play around with it for a bit, I use it all the time
There's too many features to go into detail
But with the media player open you can Left click the top left corner and check out all it's preferences
Things like, Default screen size when it start's up and such
I think I have mine set to open at 200%
But if I right click on the screen it will fully maximize
Something like that
P.S. You may want to hold onto MalwareByte's AntiMalware
If you do, occassionally, update and run a Quick Scan
If you haven't done so yet, you can delete the following
RegQuery.exe
OTMoveit3.exe
RSIT.exe
Daft.exe
fix.reg
Also, the folders they created
C:\_OTMoveIt
C:\rsit
I suggest that you add SpywareBlaster to your protection software
SpywareBlaster by JavaCool *Will block bad ActiveX Controls
*Block Malevolent cookies in Internet Explorer and Firefox
*Restrict actions of potentially dangerous sites in Internet Explorer
Select Manual updating when installing
After installation, Check for updates
After updating, select "Protection Status" on the Left
Then select "Enable all Protection" under Quick Tasks
"Check for updates every couple of weeks"
after every update just simply click the "enable protection on all unprotected items"
or again, click on Protection Status>>enable all protection
This tool doesn't provide realtime protection, it adds registry killbits to silently help protect your computer
#65 big frank
big frank
    Member
  • Members
  • PipPipPip
  • 52 posts
Posted 14 December 2008 - 04:58 PM
Something like that
RegQuery.exe
OTMoveit3.exe
RSIT.exe
Daft.exe
fix.reg
C:\_OTMoveIt
C:\rsit
Ok, I did install spywareblaster like you recommended. Is there any better free antivirus than AVG? DO you recommend doing a online scan every so often?
#66 guestolo
guestolo
    Site Donator
  • Admin
  • 16,247 posts
Posted 14 December 2008 - 05:11 PM
I don't have the newer AVG installed right now, some have experienced slowdowns with it, not all however
You can set it's scheduler to schedule once a week I believe instead of every day
I use either Avast or AntiVir right now as free scanners on my system
Of course, you would have to get use to a new AV scanner
Since you only want one installed
Sure, doing an online scan once in awhile is not a bad idea
BitDefender is a good one
There are others, some don't remove any entries, like Kaspersky's
It's more informative
But you seem to know your way around BitDefender, you may want to run that one every so often
Here's some more info on How to prevent Malware:
Malwarebyte's Anti-Malware is not on miekiemoes list
But I'm sure she'll add it one day
You may also want to take a look at her link at the bottom of that page
Help! My computer is slow! - How to improve system performance after malware removal
#67 guestolo
guestolo
    Site Donator
  • Admin
  • 16,247 posts
Posted 17 December 2008 - 01:30 PM
I'll lock this topic as your problems appear resolved
Take care big frank :)
