Author Topic: 3 in 1 Win Qeustion  (Read 669 times)
Mr_Spock
  • Guest
3 in 1 Win Qeustion
« on: January 07, 2003, 01:44:54 PM »
I admit i\'m just a newbie on this part
But i want to make a dutch version of a 3 in 1 OS win95CWin98 SEWin Me.
i found out all but when i want to try to make an iso with CDimage i get an ISO 0f 995 MB and that\'s imposibale to burn on a 700 MB where did i go wrong
I did it all with the help of this page http://www.tech-hints.com/w98.html who can help this newbie
Thanks In front
Mr_Spock
  • Guest
3 in 1 Win Qeustion
« Reply #1 on: January 08, 2003, 10:08:53 PM »
Alright found out myself why it was so big and how to make it smaller :-), but after i burned it and treid it the menu was appering but didn\'t work i get constanly the label isn\'t working what did have to chance in my boot.cmd or in the menu
Mr_Spock
  • Guest
3 in 1 Win Qeustion
« Reply #2 on: January 10, 2003, 09:30:29 AM »
Nobody knows how to solve that problem of the error in the boot menu off when you make a choice for example 1 that is the choice for WIn95 installation you get an error back label \"w95\" and that with all the choice you can make on the c.d
Also got an other qeustion when i try to open the loader.bin file provide\'t with the root 98 folder of the http://www.tech-hints.com/w98 it\'s for a windows 2000 3 in 1 and point to the *.dat file\'s of windows 2000 serie, anyone can explain me how to make your own *.bin file for the win 3 in 1 9X/WinMe can i do that simply as an *.TXT and chance the extension to bin and do i have to point it the to the *.IMA files or the setup files of the different OS
Please need some help with this
